Введение
If the buttons are jammed, loose or damaged if can be frustrating trying to use the phone. This guide will show you how to replace any of the buttons in about 10-15 minutes.
Выберете то, что вам нужно
Using your hands, carefully remove the back panel by popping the open slit, near the headphone jack, outwards.
Using your fingernail or nylon spudger, remove the battery by lifting upward in the recess of the bottom right corner.
Using the black spudger, carefully unhinge and pry the secondary rear panel using the recessed tabs on the left and right sides.
Remove the desired button by pushing inward with the spudger or disconnecting the rubber pin connections.
