Введение
The SIM card is used for receiving and transmitting signals as well as holding contacts in memory. If you are unable to take or make calls, you may need a new SIM card. Removing the SIM card is as simple as removing the battery, and you can easily use your fingers to remove the card.
Запчасти
Никакие детали не требуются.
  1. Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone. Gently pry apart the rear case from the midframe and remove. Gently pry apart the rear case from the midframe and remove.
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side. Gently pry the battery from the back of the phone. Gently pry the battery from the back of the phone.
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case. Carefully remove mid-frame from the front panel.
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Carefully remove mid-frame from the front panel.
  5. Remove or replace SIM Card by pushing into metal slot above the battery holder. Remove or replace SIM Card by pushing into metal slot above the battery holder. Remove or replace SIM Card by pushing into metal slot above the battery holder.
    • Remove or replace SIM Card by pushing into metal slot above the battery holder.
Заключение
Keon Horahan
Участник с: 13.10.2014
809 Репутация
Автор 6 руководств
Команда
Clemson, Team 3-3, Benson Fall 2014 Member of Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 5
За 30 дней: 21
За всё время: 1,932
