Введение
This guide will illustrate how to replace the front camera.
Выберете то, что вам нужно
Looking at the back of your phone, use your finger to remove back cover.
With a small phillips-head screw driver, remove the six screws holding the back panel in place.
Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, gently lift connectors from motherboard.
A connector will be on the upper left
The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
Use the tweezers to carefully remove the 2 adhesive orange ribbons.
These stay attached to the motherboard so be careful not to break them.
They are on the side of the phone.
Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
Hold motherboard so that the circuits face away from you
Pop off the two black tabs on the upper most part of the motherboard.
Gently take the front camera with two fingers and pull upwards. A wiggle may help.
