Запчасти
Никакие детали не требуются.
  1. Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Use a flat tool to pry the two plastic cases apart The latches are very strong, so don't be afraid to use force
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  5. Locate the missing button slot Place in replacement button, and close the plastic housing around it The button should be fully functional now, repeat past steps to reassemble the phone
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
Заключение
Dustin
Участник с: 12.03.2014
966 Репутация
Автор 5 руководств
Команда
University of Maryland, Team 6-2, Vijaybhaskar Spring 2014 Member of University of Maryland, Team 6-2, Vijaybhaskar Spring 2014
UMD-VIJAYBHASKAR-S14S6G2
4 членов
Автор 8 руководств
Один комментарий
Please can someone help me with samsung t769 power way on the board ?
Nyawu Ebenezer - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,050
