Введение
This guide will allow any user of the Samsung Galaxy S Blaze to properly replace the volume rocker. Replacing the volume rocker in a Samsung Galaxy S Blaze is an easy process with no surprises.
Keep in mind to be careful while handling the screws for the phone, as they will damage easily.
Выберете то, что вам нужно
Start by removing the back plate to expose the battery by pulling the back and front plates apart.
Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
Work around the phone with the tool until the frame is off.
Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Еще один человек закончил это руководство.
