Введение
If you have a Samsung GALAXY SII with broken Touchscreen or LCD Display, this manual will guide, how to change them.
This procedure is very hard. You must have good experience to do this !!!
Same steps you can use for replacing Touchscreen&LCD display with frame. This operation is more easy. If you haven't enough experience, I strongly recommend you, to choose this variant.
_______Video manual_______
Инструменты
Запчасти
Детали не указаны.
Видео обзор
Remove your battery, the SIM card and the SD card.
Remove the 7 screws highlighted in red.
At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
Use a hot air to soften the adhesive enough to remove the glass.
With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
Install the LCD&Digitiser on it's housing.
Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
32 участников успешно повторили данное руководство.
Комментариев: 8
I attempted to replace the display glass alone on a Virgin Mobile Galaxy SII, and was unsuccessful. Removing the Glass from the Digitizer proved to be extremely difficult. It seems as if the Virgin Mobile version of the SII is not meant for repair, so easily.
To moderators :
please there is a photo of a babe in the video tutorial and in the photo tutorial, not for children.
how much the cost in replacement display with fame.....samsung galaxy s2
