Введение
Use this guide to replace the rear-facing camera.
Выберете то, что вам нужно
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
Pry along the top right side, and continue prying down the right side of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
Grasp and remove the SIM card away from the phone.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Use your thumb to slide the microSD card out of the slot.
Remove the microSD card from the phone.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
Gently move the cable out of the way of the motherboard.
Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
Use a plastic opening tool to pry the rear-facing camera connector from its socket.
32 участников успешно повторили данное руководство.
3 Комментариев
Hola es muy bueno el tutoril pero yo tengo un problema y es que la camera de mi samsung galaxy s3 no funciona cuando quiero hacer selfie se bloquea me toca ir a aplicaciones borrar todo sus ajustes para poder usar la de nuevo he probado también con app de otros pero a la hora de hacer selfie se bloquea y toca borrar sus ajustes,por lo demás funciona bien
Is it possible to extend the camera strip for the rear facing camera so it could be taken out of the case and make it forward mounted (as an example)? How would you go about this I have an old s3 and want to adapt it into a hidden spy camera for when I am away to watch the house
I simply followed these instructions and the repair worked perfectly. Many thanks indeed for your help.
