Введение
Use this guide to replace the front panel assembly, including the digitizer, speaker, and OK button on the Samsung Galaxy S Plus (i9001)
  1. Unscrew 7 screws on the rear using a Phillips screw driver. Unscrew 7 screws on the rear using a Phillips screw driver.
    • Unscrew 7 screws on the rear using a Phillips screw driver.
  2. Unhook the rear using a soft plastic prying tool to remove the rear cover Be careful not to damage the rear cover when unhooking it. Be careful not to damage the rear cover when unhooking it.
    • Unhook the rear using a soft plastic prying tool to remove the rear cover
    • Be careful not to damage the rear cover when unhooking it.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
    • Detach the Power Key FPCB, that is stick to the bracket by a double-sided tape, using tweezers. Make sure to remove all remaining tape on the bracket.
  5. Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnect LCD Connector,Receiver Connector, Sub-touch Key Connector and Antenna cable from the Main PBA
    • Disconnecting the camera connector isn't necessary!
  6. After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • After disconnecting the connectors carefully pull the Main PBA out of the bracket.
    • Make sure that the Power Key FPCB does not get stuck!
  7. Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame Pull out the Receiver module from the bracket. Be careful not to damage the FPC. Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
    • Remove the antenna cable from the main Antenna PCB on the sub-touch key module of your broken Screen Digitizer Frame
    • Pull out the Receiver module from the bracket. Be careful not to damage the FPC.
    • Now assembly both Receiver module and antenna cable into the new Screen Digitizer Frame and reverse the process of disassembly!
Заключение
13 участников успешно повторили данное руководство.
Joao de Matos
Участник с: 02.07.2013
362 Репутация
1 Guide authored
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 5
За всё время: 7,844
