Введение
If your camera stops working or there are constant smudges or discoloration spots in your pictures, your camera lens may be broken or malfunctioning. Replace it by following these steps.
Выберете то, что вам нужно
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove the battery by pushing the bottom edge of the battery up and away from the phone
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
