Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the small slit on the bottom edge of the device between the back and front cases.
Pop the back case off by inserting your finger and pulling the case away from the phone.
Remove the battery by pushing the bottom edge of the battery up and away from the phone
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Disconnect the antenna using Tweezers. Do the lower end first, and then the upper.
Pull the antenna cable out.
Locate the three snap on ribbon cable connectors on the motherboard.
Carefully disconnect the ribbon cable connectors using the Plastic Opening Tools.
With the three ribbon cable connectors detached, the motherboard can be folded over to the left.
The motherboard will still be connected to the body of the phone by the power button's ribbon cable, which is glued in place.
Remove the power button ribbon cable from the body of the phone by using the Plastic Opening Tools.
With the motherboard removed, the Headset Jack and Ear Speaker are now accessible.
Use the Plastic Opening Tools to gently pry up the Headphone Jack to remove it from the body of the phone.
Disconnect the Ear Speaker from the body of the phone be gently prying up the speaker using the Plastic Opening Tools.
The connection holding the Ear Speaker in place is the same kind as the snap on ribbon cables that were disconnected in a previous step.
With the Headphone Jack and Ear Speaker both disconnected from the body of the phone, they can be removed from the phone and set aside.
Еще один человек закончил это руководство.
