Samsung Galaxy S10 Rear-Facing Camera Module Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Remove the SIM tray: шаг 1, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Remove the SIM tray: шаг 1, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Remove the SIM tray: шаг 1, изображение 3 из 3
    • Insert a SIM card eject tool, SIM eject bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress seal are mounted out of harm's way.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Mais dans quel compartiment faut-il mettre la carte sim ? Le petit ou le grand ? Je ne sais pas si “Nano” c’est le plus petit format. Merci.
    Bernard LEROY - Ответить
    Bonjour Bernard,
    La carte SIM doit aller dans le petit compartiment.
    Arthur Shi -
    Be very careful to ensure that the SIM card does not fall out of the carrier while you are sliding it into the phone.
    If it does fall out of the carrier while being inserted, you will find it nearly impossible to retrieve without damaging the phone circuitry.
    You've been warned.
    Patsy Hetzel - Ответить
  2. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Heat the back cover: шаг 2, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Heat the back cover: шаг 2, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Heat the back cover: шаг 2, изображение 3 из 3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
    I think we should mention that the glass needs to be barely too hot to touch to determine when it's hot enough that a pick can be slid underneath.
    Or we can mention a thermometer temperature, but most diy people probably don't have a thermometer to check.
    A lot of people seem to have issues using the iopener to unglue phone parts like back glass (can Google it), likely because the glue didn't get hot enough, so mentioning the desired touch temperature can be helpful for DIYers to ensure that their glue is sufficiently weakened and they can begin working off the part.
    (Just being hot isn't enough for glue to weaken, as you can probably attest to if you've ever had your phone get really hot but the back cover never came loose)
    A X - Ответить
  3. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Create an opening gap: шаг 3, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Create an opening gap: шаг 3, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Create an opening gap: шаг 3, изображение 3 из 3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
    Will the Suction Cup work with a cracked back?
    Red Royal - Ответить
    Might be hard with the suction cup on a cracked back. I'd rather break it off and buy a new back (it's super cheap, around 10$ online).
    Guenter -
    Yes! Apply a layer of packing tape to the cracked back cover first, and the suction cup will adhere to the smooth tape surface.
    Arthur Shi -
    I will open the one that I am taking out of the computer now and then I will follow where it is
    cabdi salaan - Ответить
    Am besten 2 mal gut erwährmen. Danach geht das öfnen top.
    Martin Thiel - Ответить
  4. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Insert an opening pick: шаг 4, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Insert an opening pick: шаг 4, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Insert an opening pick: шаг 4, изображение 3 из 3
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts.
    • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again. The glass is heated enough when it is barely too hot to touch.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
    I had trouble lifting up to create a gap. What I did is watch Jerry rig everything's teardown and he said the back glass must be barely too hot to touch in order for the adhesive to weaken.
    So I heated the iOpener till it was too hot to touch, but not so long that it would burst. Put on right edge for a few minutes. Then I lift with the suction cup, using my middle finger and thumb to grip the sides of the phone and my pointer finger to pull up on the suction cup .
    I cleaned the glass with an alcohol wipe beforehand to make the suction cup stick better, though I'm sure any cleaning method that removes fingerprints will help.
    I couldn't make as big a gap as shown in the picture, but I was able to stick my metal jimmy tool carefully into the crack between the glass and the metal frame and it was just enough to slide the tool a little. And I was very careful since it's a metal tool. After that I could stick the plastic pick in and slice the adhesive and then that gets you started removing the back cover. Reheat often to weaken and slice adhesive. STOP and reheat if it even gets a little harder to slice. DON'T risk cracking the glass.
    A X - Ответить
    I think we should add that they should treat the back glass as gently as a raw eggshell. That's because I thought I wasn't applying excessive force and caused the glass to crack, but I didn't understand what counts as "excessive force." (A bit vague)
    What excessive force actually means is as soon as you feel any resistance at all when slicing glue with the pick, stop and apply more heat before continuing. The glass can crack very very easily, when pressure is applied in only a small section.
    A X - Ответить
    See for me it was weird, the glass was weirdly weak. I just put the iOpener in the microwave and put it on there until it was almost too hot to touch and went around, the gap was like 0.5cm already, so I just went around and it came all off in like 10 seconds, I was kind of happy how easy it was, but sadly I went around too fast and now there's a line crack at the top left of my back glass, it's not sharp so it doesn't bother me.
    Oliver Fallon -
  5. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Slice through the adhesive: шаг 5, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Slice through the adhesive: шаг 5, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Slice through the adhesive: шаг 5, изображение 3 из 3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  6. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 6, изображение 2 из 2
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  7. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 7, изображение 3 из 3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  8. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 8, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 8, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 8, изображение 3 из 3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    Thank's for the help I will try to repair my phone with a new battery all on my
    ron hayes - Ответить
  9. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Remove the midframe: шаг 9, изображение 1 из 1
    • Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
    ネジが堅くて回らず、緩める方法はありますか?
    win1683 - Ответить
    ネジロックが原因である可能性があるため、iOpener で熱を加えてみてください。
    Oliver Fallon -
  10. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 10, изображение 2 из 2
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
    • Pry up to loosen the midframe from the phone.
    Bei mir war die Kerbe durch den Klebstoff komplett verdeckt. Am bestern den Kleber vorher entfernen. Dann geht es einfacher.
  11. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 11, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 11, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 11, изображение 3 из 3
  12. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Disconnect the battery: шаг 12, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Disconnect the battery: шаг 12, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Disconnect the battery: шаг 12, изображение 3 из 3
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
  13. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Remove the loudspeaker: шаг 13, изображение 1 из 1
    • Remove the seven 4 mm Phillips screws securing the lower midframe.
  14. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 14, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 14, изображение 2 из 2
    • Insert the point of a spudger underneath the top right corner of the lower midframe.
    • Pry up to release the midframe from the phone.
  15. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 15, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 15, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 15, изображение 3 из 3
    • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
    • Wiggle the midframe slightly to help release the remaining edge clips.
    • Remove the lower midframe. The loudspeaker is built into the lower midframe.
  16. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Motherboard: шаг 16, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Motherboard: шаг 16, изображение 2 из 2
    • Use the flat end of a spudger to pry up and disconnect the display connector from its motherboard socket, located near the bottom right corner of the phone.
  17. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 17, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 17, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the headphone jack's connector from its motherboard socket.
    It's a good idea to take out the headphone jack at this point.
    It eases the process of taking out the motherboard.
    When reinstalling a new motherboard, the advantage of pushing in the jack AFTER sitting the motherboard is even greater
    Tal Glazer - Ответить
  18. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 18, изображение 1 из 1
    • Remove the three 3.7 mm Phillips screws securing the motherboard to the phone.
  19. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 19, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 19, изображение 2 из 2
    • Insert the point of a spudger underneath the right edge of the motherboard, near the volume down button.
    • Pry up gently to loosen the motherboard from its recess.
  20. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 20, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 20, изображение 2 из 2
    • Insert the point of a spudger under bottom left corner of the motherboard.
  21. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 21, изображение 3 из 3
    • Using your fingers, grasp the motherboard by the top corners.
    • Swing the motherboard slightly out of its recess. Be careful not to snag any cables along the way.
    • Pull the motherboard towards the top edge of the phone while wiggling the board slightly. This will loosen the charging port from its socket.
    • Once the charging port is freed from its socket, remove the motherboard.
    • To reinstall the motherboard:
    • Align the motherboard's charging port with the bottom edge of the phone.
    • Gently push the motherboard against the bottom edge of the phone until the charging port is completely seated.
    • Lower the motherboard and press into place. Be careful not to trap any cables underneath the motherboard. The board should sit flush against the frame.
    It's a better idea to take out the headphone jack before taking out the motherboard and reattaching the jack after you sit the new motherboard in
    Trust me...
    where can you get replacement motherboard?
    Christopher Martinez - Ответить
  22. Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: шаг 22, изображение 1 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: шаг 22, изображение 2 из 3 Samsung Galaxy S10 Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: шаг 22, изображение 3 из 3
    • Flip the motherboard over.
    • Use the flat end of a spudger to pry up and disconnect the two camera connectors from their sockets on the motherboard.
  23. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 23, изображение 1 из 1
    • Heat an iOpener and lay it over the rear-facing camera module for one minute.
  24. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 24, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 24, изображение 2 из 2
    • Insert the point of a spudger under the top-left corner of the camera module, where there is a small notch.
    • Pry up to loosen the camera module from the motherboard.
  25. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 25, изображение 1 из 2 Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 25, изображение 2 из 2
    • Insert the edge of an opening tool under the loosened corner of the camera module.
    • Pry up to release the camera module from the motherboard.
  26. Samsung Galaxy S10 Rear-Facing Camera Module Replacement: шаг 26, изображение 1 из 1
    • Remove the rear-facing camera module.
Заключение
After you've completed the repair, follow this guide to test your repair.
11 участников успешно повторили данное руководство.
Arthur Shi
Участник с: 01/03/18
252 733 Репутация
Автор 526 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
8 Комментариев
I only wanted to know, what cameras are used in Galaxy S10/e, are they from Sony or Samsung used its own?
Hanif Ali Baloch - Ответить
I’m sure I could combine info and figure it out on my own, but is there anywhere I can find instructions on only replacing the camera lens glass? I’m not the best at figuring this stuff out and getting it right. Any help is appreciated.
Riley Crawley - Ответить
Hi, I had to replace the cover on my lens, and now the only one that focuses clear is .5. The rest are blurry. IF I replace this, will it fix that?
Jeanie Compton - Ответить
i having camera issue, camera failed . Even check with *#0*# camera still unable. Changing the camera module will solve this?
ngoh aywen - Ответить
hello, if you have an authorized Samsung dealer around you they can diagnose the problem at a very affordable fee
mcsmart pain -
The tools list includes Tesa tape. But I don’t see where tape is used in this guide. Do we actually need to buy this to replace the camera module?
Benjamin Hershberg - Ответить
Hi Benjamin! I added Tesa tape in the tools list as the adhesive to reattach the back cover. If you have replacement back cover adhesive on-hand, you don’t need Tesa tape.
Arthur Shi -
No but you may need it to stick the rear glass back on
Alan Sears -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 61
За последние 30 дней: 254
За всё время: 24,637
