Введение
The Galaxy S10 has a hybrid SIM card tray. Ejecting this tray allows you to replace the nano SIM card, add a microSD memory card, or add a second nano SIM card (certain models only).
Инструменты
Запчасти
Детали не указаны.
Insert a SIM card eject tool, SIM eject bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
Press firmly to eject the tray.
Remove the SIM card tray.
After you've completed the repair, follow this guide to test your repair.
3 участников успешно повторили данное руководство.
Один комментарий
Bravi, guida semplice e perfetta, molto chiara. Complimenti!
Mais dans quel compartiment faut-il mettre la carte sim ? Le petit ou le grand ? Je ne sais pas si “Nano” c’est le plus petit format. Merci.
Bernard LEROY - Ответить
Bonjour Bernard,
La carte SIM doit aller dans le petit compartiment.
Arthur Shi -
