Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite guide only! Removes the top midframe, which includes the charging coil and NFC antenna, for the Samsung Galaxy S10.
Выберете то, что вам нужно
Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
The midframe is still held in place by a few plastic clips around the edge.
Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
Pry up to loosen the midframe from the phone.
Lift the midframe from the top corners and remove it from the phone.
To reinstall the top midframe:
Align the midframe's top edge to the phone and lay the frame down on the phone.
Use fingers to apply pressure along the midframe perimeter to snap the midframe clips back into place. The edges should sit flush against the phone edge.
