Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn your phone off completely before you begin this repair.
Prepare an iOpener and heat the back of the phone along the right edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
Secure a suction cup to the back cover, as close to the heated edge as possible, just under the Bixby button where the adhesive is thinnest.
Prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick. This will angle the phone so that the opening tool is easier to insert.
Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Press the edge of an opening tool into the gap.
Slide the opening tool along the right edge of the phone to slice through the adhesive securing the back cover.
Insert an opening pick into the edge next to the opening tool. Leave the pick here to prevent the separated glue from re-adhering.
Apply a heated iOpener to the top edge of the phone for two minutes.
Insert an opening pick near the top right corner of the phone and slide it around the corner and across the top edge of the phone.
Leave the opening pick in place to prevent the adhesive from re-adhering.
Apply a heated iOpener to the left edge of the phone for two minutes.
Insert a new opening pick near the top left corner and slide it along the left edge of the phone.
Again, leave the opening pick in place in the left edge of the phone to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the phone for two minutes.
Insert an opening pick near a bottom corner of the phone, and slide it along the bottom edge of the phone to separate the adhesive there.
Use the opening picks to very carefully pry up the back cover.
If you encounter any resistance, stop prying and use an opening pick to cut any remaining adhesive.
Remove the back cover.
9 участников успешно повторили данное руководство.
5 Комментариев
I just replaced the lens today. I discovered you actually don't even have to remove the back of the phone IF all you're doing is replacing the glass.
