Введение
Galaxy SII Screen Replacement Tutorial
Выберете то, что вам нужно
Now disconnect all connectors on the motherboard, making sure the front camera and buzzer. This is attached with the double-sided adhesive. As a precaution, remove the audio ear speaker. In all this we will always help with a plastic instrument and a spudger.
Remove with a thin tool "iSesamo" the volume rocker and power switch side, these are fixed with adhesive tape
Remove the USB connector by unscrewing the two screws. Reinstall the new display starting from this step to number one on the procedure.
61 участников успешно повторили данное руководство.
Один комментарий
Hello AndreaBaglione,
We are iphone lcd dealer in China, and looking for original Iphone lcd, especially for 5G, both new and used accepted, quantity will be over 1000 and even more. Would you let me know whether you are doing this business or any channel that you can recommend? Thank you in advance. lihanshan@163.com
Best regards
Fiona
