Samsung Galaxy S21 Plus Vibration Motor Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S21 Plus Vibration Motor Replacement, Heat the back cover: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Plus Vibration Motor Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 5, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 5, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 5, изображение 3 из 3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 6, изображение 3 из 3
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the back cover: шаг 7, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the back cover: шаг 7, изображение 2 из 2
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 8, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 8, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Slice the adhesive: шаг 8, изображение 3 из 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 9, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 9, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement: шаг 9, изображение 3 из 3
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the charging coil: шаг 10, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the charging coil: шаг 10, изображение 2 из 2
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the NFC antenna: шаг 11, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the NFC antenna: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Plus Vibration Motor Replacement, Unfasten the NFC antenna & charging coil assembly screws: шаг 12, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 3 из 3
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the battery cable: шаг 14, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the battery cable: шаг 14, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the display flex cable: шаг 15, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the display flex cable: шаг 15, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable by prying its upper connector straight up from its socket.
  16. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the main & interconnect flex cables: шаг 16, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the main & interconnect flex cables: шаг 16, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the main & interconnect flex cables: шаг 16, изображение 3 из 3
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  17. Samsung Galaxy S21 Plus Vibration Motor Replacement, Unfasten the earpiece speaker assembly screws: шаг 17, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the earpiece speaker assembly.
  18. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the earpiece speaker: шаг 18, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the earpiece speaker: шаг 18, изображение 2 из 2
    • Use a spudger to disconnect the earpiece speaker cable by prying the connector straight up from its socket.
  19. Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the earpiece speaker assembly: шаг 19, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the earpiece speaker assembly: шаг 19, изображение 2 из 2
    • Insert a spudger underneath the bottom left edge of the earpiece speaker assembly.
    • Use your spudger to pry up the earpiece speaker assembly.
  20. Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the earpiece speaker assembly: шаг 20, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the earpiece speaker assembly: шаг 20, изображение 2 из 2
    • Use a pair of tweezers or your fingers to carefully remove the earpiece speaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  21. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the front facing camera: шаг 21, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the front facing camera: шаг 21, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the front facing camera: шаг 21, изображение 3 из 3
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
  22. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the power button flex cable: шаг 22, изображение 1 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the power button flex cable: шаг 22, изображение 2 из 3 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the power button flex cable: шаг 22, изображение 3 из 3
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
    • Use your spudger to carefully bend the flex cable to the side to avoid damaging it during the motherboard removal.
  23. Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the antenna flex cable: шаг 23, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Disconnect the antenna flex cable: шаг 23, изображение 2 из 2
    • Use a spudger to disconnect the power antenna flex cable by prying the connector straight up from its socket.
  24. Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the motherboard assembly: шаг 24, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the motherboard assembly: шаг 24, изображение 2 из 2
    • Make sure no cables are tangled with the motherboard assembly during the removal procedure to avoid cable damage.
    • Insert a spudger underneath the top edge of the motherboard assembly and next to the vibration motor.
    • Use your spudger to pry up the motherboard assembly.
  25. Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the motherboard assembly: шаг 25, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the motherboard assembly: шаг 25, изображение 2 из 2
    • Carefully remove the motherboard assembly including the rear cameras.
  26. Samsung Galaxy S21 Plus Vibration Motor Replacement, Loosen the vibration motor adhesive: шаг 26, изображение 1 из 1
    • Prepare an iOpener and apply it to the screen where the front facing camera is located for at least two minutes to loosen the adhesive underneath the vibration motor.
  27. Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the vibration motor: шаг 27, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Pry up the vibration motor: шаг 27, изображение 2 из 2
    • Carefully insert one arm of a pair of tweezers underneath the vibration motor connector.
    • Use your tweezers to pry up the vibration motor.
  28. Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the vibration motor: шаг 28, изображение 1 из 2 Samsung Galaxy S21 Plus Vibration Motor Replacement, Remove the vibration motor: шаг 28, изображение 2 из 2
    • Use your pair of tweezers to lift the vibration motor out of its recess and remove it.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Участник с: 11/23/16
172 783 Репутация
Автор 676 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 729 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 64
За всё время: 620
