Samsung Galaxy S4 Active Vibrator Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: шаг 1, изображение 1 из 2 Samsung Galaxy S4 Active Vibrator Replacement, Rear Case: шаг 1, изображение 2 из 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Vibrator Replacement, MicroSD Card: шаг 2, изображение 1 из 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Vibrator Replacement, Battery: шаг 3, изображение 1 из 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Vibrator Replacement, SIM Card: шаг 4, изображение 1 из 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Vibrator Replacement, Midframe: шаг 5, изображение 1 из 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Vibrator Replacement: шаг 6, изображение 1 из 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: шаг 7, изображение 1 из 3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: шаг 7, изображение 2 из 3 Samsung Galaxy S4 Active Vibrator Replacement, Motherboard: шаг 7, изображение 3 из 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Vibrator Replacement: шаг 8, изображение 1 из 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Vibrator Replacement: шаг 9, изображение 1 из 1
    • Remove the motherboard.
  10. Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: шаг 10, изображение 1 из 2 Samsung Galaxy S4 Active Vibrator Replacement, Vibrator: шаг 10, изображение 2 из 2
    • Use tweezers to gently remove the vibrator.
Заключение
3 участников успешно повторили данное руководство.
atika5656
Участник с: 10/21/14
167 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 3,548
