Введение
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
99 участников успешно повторили данное руководство.
Один комментарий
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
