Введение
Use this guide to replace your Samsung Galaxy S4 display assembly.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    I snapped the back cover sorry m8
    Daniel Anishchenko - Ответить
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above pic and found the divot and was able to take off the rear cover as per the “Step 1 rear cover” instructions.
    Terry Crawford, Jr. - Ответить
  2. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Ответить
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
  3. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the microSD card.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Remove the battery from your phone. Remove the battery from your phone.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    I was able to remove the Samsung Battery with the blue plastic opening tool(AKA: Spudger) as per the Step 4 Battery instructions.
  5. Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the SIM card.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Ответить
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Ответить
    I was able to remove the SIM Card with the blue plastic opening tool(AKA: Spudger) with no problems as per the Step 5 SIM Card instructions.
    Hello, how can I change the sim card slot itself? I think I damaged it.
    daejung - Ответить
    same issue as above, appears bent upward and will not click down in
    Jer S - Ответить
  6. Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    How much it will cost to replace a midframe
    kannan - Ответить
    How much cost will be on replace a midframe
    Hiren pedhadiya -
    I'm seeing midframes available on Ebay for around $10.
    Alex - Ответить
    I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
  7. The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe. Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece.  Look for the seam between the two.
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
    I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
    nicosoranno4gxo - Ответить
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
    This blue Case Opening tool has a less rigid edge that is kinder to trim than the hard black Spudger shown in later steps. I was glad to have the right tool on hand at this step. Use it as a wedge and slide it along the gap.
    Tom Huber - Ответить
  8. Continue prying around the corner of the phone. Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Again, pry around the corner, to the power button side. Slide the opening tool along the seam.
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly. At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
    josephoswald - Ответить
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
  11. Remove the midframe from the display assembly. Remove the midframe from the display assembly. Remove the midframe from the display assembly.
    • Remove the midframe from the display assembly.
    here i leave them a video i made doing the work
    https://www.youtube.com/watch?v=85pOvI6O...
    enjoy
    Gabriel Barrandeguy - Ответить
    Just to be sure does the rear frame referred by etradesupply is the same as the middle frame? I' planning to refurbish the side panel because of the dents and scratches but I just want to make sure I'm buying the right thing. The etradesupply referring the housing as rear and front housing so Im not sure which one correspond to the middle frame. Below is the link to the website http://www.etradesupply.com/oem-samsung-...
    Mohd Bahij Ahmad - Ответить
    My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
    Michael Willis - Ответить
    Just did this on my S4. Instructions were extremely helpful, but I had to remove a screw (step 10.5?) to remove the upper display assembly bracket. Other than that, flawless! Thanks!
    JackieME - Ответить
    The 3rd image of the 11th step shows that when the midframe is removed, some parts come along with it (at the bottom part of it). What are these parts? should they be removed too and placed in the new midframe? Are they easy to remove?
    Chris - Ответить
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them. In Step 11 is just the separating the midframe from the display assembly 100%. So far these instructions have been 100% correct for a Samsung Galaxy S4.
  12. Use the flat end of a spudger to disconnect the USB board connector. Disconnect the front-facing camera cable connector. Disconnect the earpiece speaker assembly cable connector.
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    Does it matter which motherboard I get? Why are there different prices depending on the phone company?
    Zoe Carpenter - Ответить
  13. Disconnect the headphone jack assembly cable connector. Disconnect the display/digitizer cable connector. Disconnect the antenna cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
    Replacing the S4 advance display, I've broken the plug on motherboard of the antenna, which part should I replace now ?
    Second question, when display replaced, the "home" buttton was working just as the "return", did I make a wrong thing ? (perhaps ending the daughterboard) and what is the countermeasure ?
    LEMEUR JMarc - Ответить
    My model had an antenna connection next to the usb board connector in addition to the antenna connection near the display cable connector.
    Drew - Ответить
    That's point a, on the daughter board (where the USB is located is point b. You must connect it from a to b
    djweijers1997 -
    Same as Drew. My model has two antenna connections. One as shown, and one on the left side of the motherboard.
    Gavin McMorrow - Ответить
    Mine does too. I can't get that one to reconnect. What is it?
    seeshelle -
    I could not get the screen connector to fit on with the motherboard assembly in place. I had to remove the motherboard assembly, attach the screen connector, and then carefully replace the motherboard assembly, with the screen connector still attached..
    Tom4G - Ответить
    Same as Tom4G above. When trying to connect the screen connector, it would not give me that nice clear snap indicating a positive connection. The phone powered up with no screen. So, I disconnected the other connectors again, lifted the motherboard out and connected the screen connector by pinching it with finger and thumb from both sides of the motherboard, this time getting a nice snap when it engaged.
    speedrzr -
  14. Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    As Sam Lionheart states at the end of this guide, some of these phones have an additional antenna on the opposite side of the phone. Be sure to detach it before removing the motherboard.
    mcr4u2 - Ответить
  15. Gently remove the motherboard. Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  16. Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
    • Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
    My assembly had a silver conductive tape shield over the array of components shown in the middle of this photo. I peeled the old one off and attached it in the same location on my new digitizer.
    David - Ответить
  17. Remove the headphone jack assembly.
    • Remove the headphone jack assembly.
    The headphone jack is surrounded by rubber. It's kind of squeezed in there. You can pry on it to get it out.
    jonathan - Ответить
    I had a quick question there's a little white rubber circular gasket piece that the headphone jack covers up
    What's that piece called?
    damian lasher - Ответить
    The small rectangular milky-white silicon gasket appears to be a diffuser for ambient light sensor.  I removed it with a small screwdriver, and replaced it in the same location in my new screen assembly.
    Nicholas Crisp -
    The small rectangular milky-white silicon gasket appears to be a diffuser for an ambient light sensor.  I prised it out of the old assembly and placed it in the new screen assembly.  I also started transferring the components as they were removed from the old screen, so the head-phone jack went straight into the new at this point.  I may regret that later…
    Nicholas Crisp -
    The angle of the picture here makes it appear like the head phone jack needs to be slid out of the top of the phone. This is impossible due to small bits of plastic holding it in at the top. If you're having trouble, the headphone jack is in fact supposed to lift straight up out of the phone.
    sigoshi - Ответить
    Additionally, there might be a small amount of adhesive holding the headphone jack to the board (there was some in my device). Apply a bit of heat to loosen it up, if needed.
    Mikolaj Banasik - Ответить
    it is easy to pop off, if you apply pressure to the right point. Using a plastic pair of tweezers or a pry tool, push at the lower right corner and gradually increase the pressure, if you apply enough pressure it will just pop right off.
    Wissmiller Services - Ответить
  18. If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket. Remove the upper display assembly bracket from the display.
    • If present, remove the 2.4 mm PH #00 screw securing the upper display assembly bracket.
    • Remove the upper display assembly bracket from the display.
    I’ve found that a pretty easy way of popping the bracket off is to slide a thin end of the spudger from the left, then delicately push in - it just popped off easily in my case.
    Be careful with this part! It is very springy. I was gently trying to lift it and it shot across the room!
    NikonErik - Ответить
  19. Remove the front-facing camera from the display assembly.
    • Remove the front-facing camera from the display assembly.
  20. Remove the earpiece speaker assembly from the display assembly.
    • Remove the earpiece speaker assembly from the display assembly.
  21. Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly. Be careful not to immediately remove the vibrator, as its cable is also adhered to the rear of the display assembly. Use the tip of a spudger to pry the vibrator cable up from the display assembly.
    • Insert the tip of a spudger under the vibrator to free it from the adhesive holding it to the display assembly.
    • Be careful not to immediately remove the vibrator, as its cable is also adhered to the rear of the display assembly.
    • Use the tip of a spudger to pry the vibrator cable up from the display assembly.
    • Heat works as a great "persuader" here to soften the adhesive. Liberal application of heat from a heat gun will soften the adhesive. If you pry carefully, you can save and re-use the adhesive.
    also you can really feel free to dig the motor out as the housing will be discarded.
    Pavlina G - Ответить
    I would suggest getting the cable loose first as the vibrator comes out suddenly and you could break off the cable if it is still glued down.
    ken - Ответить
  22. Remove the vibrator from the rear of the display assembly.
    • Remove the vibrator from the rear of the display assembly.
  23. Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post. Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post.
    • Gently insert the point of a spudger between the USB port and the USB port bracket to pry one side of the bracket off of its post.
    Use a tiny screwdriver to pry up next to the left post of the USB port bracket instead of the spudger and it will pop right off. I tried the spudger but it didn't work for me.
    computeripodrepair - Ответить
  24. Remove the USB port bracket from the USB port.
    • Remove the USB port bracket from the USB port.
    • The bracket is slightly springy and should pop back into place on the two screw posts during reassembly.
  25. Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board Disconnect the antenna connector cable from the USB board.
    • Disconnect the soft button cable from the USB board cable. Be extra careful here, once you have removed the cable, carefully peel it away from the USB board
    • Disconnect the antenna connector cable from the USB board.
  26. The USB board is secured to the display assembly with light adhesive. Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place. Go slow and be careful not to bend the board.
    • The USB board is secured to the display assembly with light adhesive.
    • Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place.
    • Go slow and be careful not to bend the board.
    This one was a bit tricky. The board was very tight to the frame so I ended up having to remove the board from the opposite side slowly until I got to the front, then used the tool to remove it.
    mitch - Ответить
    I also had the most trouble with this part -- it's very well-glued to the assembly, so I used my hair dryer to loosen it somewhat and pried it up with tweezers. This seems to be the part most likely to crack (because it's long and glued down the entire length of the board), so I recommend patience and a little heat to help things along.
    Andrew Richards - Ответить
    why do you respond in english when this discription is written in german ?!! XD
    alen91 - Ответить
    I’ve found that applying the heat loosens up the adhesive, making it easier to remove the board.
    You can either use a heat gun on lowest setting, or a hair dryer, to apply heat to the board area, then start slowly from the left side. Adhesive appears to be applied as a strip of materials, so with enough care, you can keep it in place and for keeping the USB board in place after reassembly.
    Double-sided tape was used in the i9500 version I used. Be very slow. Heat from a hair dryer helped.
    Chris Chaulk - Ответить
    Working on Verizon SCH-i545, if you’ll follow the instructions, they really do help. The board will bend ever so slightly because your spudger is crafted at an angle by default. The key is to roll it out, and literally keep the spudger as close to the frame as possible. I removed mine with no heat application. I’ll update this once the repair is completed to let you know how the overall process was and what galaxy diags say once the phone is back together. #StrivelinkTech
    Sturgis Baxter - Ответить
    Repair went well, hardware working as desired. Used a B stock part to replace the screen since it’s a beater phone repair anyway. Board works fine, went back in smoothly with no heat applied.
    Sturgis Baxter -
  27. Remove the USB board from the display assembly.
    • Remove the USB board from the display assembly.
  28. Peel up and remove the antenna connector cable from its channel in the rear of the display assembly. Other carrier models may have an additional antenna cable on the opposite side of the phone. Remove this antenna from the display assembly as well. On reassembly, it will be helpful to reinstall the USB board first, and reconnect the antenna connector cable before routing it back into its channel.
    • Peel up and remove the antenna connector cable from its channel in the rear of the display assembly.
    • Other carrier models may have an additional antenna cable on the opposite side of the phone. Remove this antenna from the display assembly as well.
    • On reassembly, it will be helpful to reinstall the USB board first, and reconnect the antenna connector cable before routing it back into its channel.
    I have like this phone exatly but I can fix it
    abdulrzaq - Ответить
    When did the display get replaced? Is the last piece trash and the phone rebuilt on the new one?
    Mark Peterson - Ответить
    Yep, the component leftover after removing the antenna interconnect cable is the display assembly. The digitizer, LCD and display frame are a glued together unit, replacing the entire assembly is much safer than trying to delaminate the display. The next step would indeed be to rebuild the phone on top of the new display assembly.
    Sam Goldheart -
    Is there any difference with the SPH-D720T (SPRINT) tri-band model? Can the non tri-band display be used on the tri-band model?
    Rafael Gomez - Ответить
Заключение
579 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
385 577 Репутация
Автор 544 руководств
Команда
iFixit Member of iFixit
Community
104 членов
Автор 9 259 руководств
Комментариев: 51
HELP! step 28 just ends how do I insert the new one, how do I resemble the parts that used adhesives to stick?
Tom - Ответить
Nearly all the guides end like this, you just need to work backwards through the steps using the new hardware.
Dave Davidson -
Just work backwards like Nick stated. I usually reverse assemble the parts I take off so I know the order in which I need to put them back in.
Sturgis Baxter -
Just run it along its track. Use a plastic spudger to push it down. Use 3m double sided adhesive tape to re-attach parts that require adhesive.
Fausto Lebron - Ответить
What is the difference between an AT&T digitizer and a Verizon digitizer? How interchangeable are they?
Martin - Ответить
I believe the digitizer is the same but if you buy the digitizer with assembly (frame) there is a difference between the models. Here are the model numbers for all the versions. I545 (Verizon) , I337 (AT&T), L720 (Sprint), M919 (T-Mobile), I9500 (International), i9505 (International)
Fausto Lebron -
Hi, I just try to repair my screen assembly with your beautiful Guide. Everything was good until I tried to turn on the phone: The "SAMSUNG galaxy S4" picture tried to displayed and stop. I can see nothing on the screen, but the phone continue the starting process with nothing on the screen.
Somebody can Help me?
It's a Samsung Galaxy S4 GT9505 version
pdesplan - Ответить
maybe you can check if you bluged in all the wires inside...
haneenbweerat -
The "display assembly" I purchased was very simple: glass and LCD and a small board with cable and that's it. It didn't have all this beefy mid frame stuff so I had to reuse my old one. Check to see which part you purchased before going through unnecessary disassembly steps like I did.
Logan Kennedy - Ответить
I wasn't clear on if the "2nd" antenna - the pinkish one on the left when over or under.....
Bobbi Jo - Ответить
This is extremely confusing...
I don't know where you got your screen but mine is coming from ET and delivered without the gray plastic crap glued on its back (which apparently costs 60$ more) but is still called a screen and digitizer assembly. Reason why I started to follow the complete guide even before opening my package...
Looking now at my dismantled phone I can tell that I basically just had to open the back, remove the screen cable from the motherboard and go to another guide to learn how to remove the digitizer.
You'll tell me that I should have read carefully before starting I know.
But the fact is that a guide designed for the replacement of the screen and digitizer assembly is still lacking here and could help a lot... really :)
Hopefully this could be built in 2 seconds using the already existing guides :)
Alexandre CARON - Ответить
I assembled mine and everything now works except the GPS, it fails to find my location or lock on. The antenna wires (I have two, one on the left and one on the right) look fine. Any ideas?
David Dunk - Ответить
followed all the steps but as soon as i was done, i discovered i have no sound :( The settings on the menu are all at full volume and i don't hear anything. I called the cell phone and no ring However i did hear my voicemail.....any help?
rod - Ответить
so i put everything back together and it fits.... however the screen won't turn on!!!! what did i do wrong :/
Kimberly Nguyen - Ответить
This guide was perfect, phone works like new again. Thank you for putting this together.
Brant - Ответить
When you get to Step 7, it is much safer (for the screen) to begin to separate the mid frame from the seam inside the battery compartment. Place the phone face down on a clean sheet of paper, put your fingernail in the seam and pull it apart with spudger. Much less likely to do any damage to the screen.
Gary McIntosh - Ответить
Help, i replaced the display assembly, but the touchscreen isn't working. any idea of what i've done wrong? or did maybe damaged something?
lilytjuhh - Ответить
This just happened to me too, I think I might have pulled the digitizer by mistake or took off the sticker on the back which might have messed up the ribbon cables, did you fix it yet? My touch screen isn't working now also.
justin -
Absolutely 100% perfect. Everything works and I have my Galaxy S4 back. Couldn't be happier!!!
macmcknight - Ответить
Thanks SOO MUCH! This was awesome. Just pay close attention to the pictures as you go, take your time, and save yourself about $150 vs having a shop do it...
Further advice: DO NOT use anything metal when prying apart the frame in the beginning... The cell phone tool kits are worth it.
jrupertnh - Ответить
kind of misleading I thought I was fixing the broken glass and it stopped in the middle so I had to research other instructional.
bjbergner - Ответить
Superb guide, got me there successfully from start to finish ... Thank you
Kevin - Ответить
Hi, my screen is broken.. and the display... I just wondered if following these steps would delete my messages and photos on the phone. i assume not as it says nothing about a factory reset but I just wanted to make sure before going ahead. Thanks in advance.
Tara - Ответить
I have two phones with the same problem. After reassembly, just before I install the midframe, I check the phone with the sim card and it works perfect. When I install the midframe I get intermittent on one phone and continuous and the other 'sim card not recognized restart the phone'. I get this, as I've said, only when the midframe is re-installed.
JustinTimeToo - Ответить
Hola tengo un galaxi s4 gt i9500 el cual se me callo y se estrello la pantalla y lo que quiero preguntar es si alguna de estas pantallas funciona en mi celular para comprarla y en cuanto me saldria
El Yampi Estevez - Ответить
Perfect! Great guide, all functions a go.
Don Joseph - Ответить
The guide is not complete, I almost throug away the main button and components coming with it, that would have been nice not to forget that.
facebout - Ответить
I have a Verizon Samsung Galaxy S4, and during disassembly I noticed that it contains two antennas - one in the position as shown in this guide and one on the exact opposite side (colored light red). It too must be disconnected in the same fashion as the antenna in this guide. Removal and installation of both antennas was simple. As the guide suggests, I would recommend installing USB board and motherboard back in place prior to reinstall and routing of antenna wires. Excellent guide. Fixed my broken S4!
coastguard26 - Ответить
thank you thank you thank you!!!! i didn't have any of the tools but used my thumb nails!
twiskinmcmillan - Ответить
Where can I buy a cheaper lcd replacement at.
Pat Howard - Ответить
Where can I buy a cheaper lcd replacement for my Samsung Galaxy s4 i337 at?
Easy. Thanks for sharing this tutorial.
Philippe RIPAUX - Ответить
hi, i am from Argentina! i want to ask if this guide is similar for the display replacement of s4mini? thanks!
Hernan Romero - Ответить
I've gone through this guide, now on reassembly, I'm trying to re-connect the large ribbon cable on the right from the screen assembly to the motherboard but the connector doesn't want to go in, is there a knack to this or something? Would appreciate any input.
Dan Tucker - Ответить
Could someone tell is it necessary to carefully with moderate pressure while re-screwing after fixing the parts to the new display ?
Krrish - Ответить
Guys I followed the instructions and everything works fine. BUT the screen lock pattern I had set doesnt work. Pleae help
Robbie Callaghan - Ответить
can i instal screen glass samsung galaxy s4 replacement without UV glue
ahssanhumadi - Ответить
I'm really having a hard time deciding on fixing my galaxy s4. The price of the screen/digitizer just doesn't seem to make the phone worth fixing. Case in point, the one advertised on this site is 229 dollars. And i can get a full samsung galaxy 4 for 170 dollars on kijij. Seems smarter to buy a new phone then to bother wasting money on a screen and digitizer, since i would pocket bucks, and still have the broken phone for parts or whatever. There is a s4 on ebay right now for 75 bucks Canadian. So how the !&&* could it ever be worth it to pay 229 dollars for a screen and digitizer. Thats an extreme case, and I have seen lots advertised around the 120 dollar mark. But i STILL dont see how payimng that for a new screen digitizer could ever be worth it, considering how much a used s4 only costs
sethwudel - Ответить
Hello this is Ajay Meshram have using a Samsung Galaxy s4 buy from UAE my display is not working how can I sort the problem
Please me
Ajay Meshram - Ответить
Hi i want s4 display no wornty i want
pratik wadhwa - Ответить
I have a Galaxy S 4 that won't turn on ! Any suggestions?. Help would be appreciated. Thanks Bcutlip2006@yahoo.com
Bernard Cutlip - Ответить
This was AWESOME! I was able to fix my phone. It took me about 2 hours as I kept stopping for breaks.
samsung s4 verizon ma samsung s4 orginal ka board lag jai ga
faizanramzan980 - Ответить
I did it, and it wasn't too hard.
Here are some tips:
- when removing the midframe, begin from the side with the volume buttons like mentioned here
- the USB board can be bent a bit, it will probably still work fine if it did not crack when you removed it.
- The GT-i9515 also uses the GT-i9505 screen
- make sure that all ribbon cables are really fully attached, apply a bit of pressure
- when reattaching the midframe, make sure to clip in the power button side first, you will have a VERY hard time clipping it on there last. I had to remove the midframe again and start at that side
Schule04 - Ответить
I tried every step right. Do you need a new glass to put on the screen
Tivek Subramoney - Ответить
Anyone know from where I can get a cheap display digitizer assembly for my s4?
Durgesh Mangal Mishra - Ответить
Great guide, helped me out alot
nev tevi - Ответить
Thanks - Works well
Rainer Nickel - Ответить
Samsung Galaxy s4 display
Balwant J - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 22
За 7 дней: 144
За 30 дней: 637
За всё время: 685,210
