Samsung Galaxy S4 Front Facing Camera Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S4 Front Facing Camera Replacement, Rear Case: шаг 1, изображение 1 из 2 Samsung Galaxy S4 Front Facing Camera Replacement, Rear Case: шаг 1, изображение 2 из 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 2, изображение 1 из 3 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 2, изображение 2 из 3 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Ответить
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Ответить
  3. Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: шаг 3, изображение 1 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: шаг 3, изображение 2 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: шаг 3, изображение 3 из 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Samsung Galaxy S4 Front Facing Camera Replacement, Battery: шаг 4, изображение 1 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, Battery: шаг 4, изображение 2 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, Battery: шаг 4, изображение 3 из 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: шаг 5, изображение 1 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: шаг 5, изображение 2 из 3 Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: шаг 5, изображение 3 из 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Ответить
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Ответить
  6. Samsung Galaxy S4 Front Facing Camera Replacement, Midframe: шаг 6, изображение 1 из 1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    How much it will cost to replace a midframe
    kannan - Ответить
    How much cost will be on replace a midframe
    Hiren pedhadiya -
    I'm seeing midframes available on Ebay for around $10.
    Alex - Ответить
    I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
  7. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 7, изображение 2 из 2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
    I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
    nicosoranno4gxo - Ответить
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
    This blue Case Opening tool has a less rigid edge that is kinder to trim than the hard black Spudger shown in later steps. I was glad to have the right tool on hand at this step. Use it as a wedge and slide it along the gap.
    Tom Huber - Ответить
  8. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 8, изображение 2 из 2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 9, изображение 2 из 2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 10, изображение 1 из 2 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 10, изображение 2 из 2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
    josephoswald - Ответить
    I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
  11. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 11, изображение 1 из 3 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 11, изображение 2 из 3 Samsung Galaxy S4 Front Facing Camera Replacement: шаг 11, изображение 3 из 3
    • Remove the midframe from the display assembly.
    My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
    Michael Willis - Ответить
    Just did this on my S4. Instructions were extremely helpful, but I had to remove a screw (step 10.5?) to remove the upper display assembly bracket. Other than that, flawless! Thanks!
    JackieME - Ответить
    The 3rd image of the 11th step shows that when the midframe is removed, some parts come along with it (at the bottom part of it). What are these parts? should they be removed too and placed in the new midframe? Are they easy to remove?
    Chris - Ответить
  12. Samsung Galaxy S4 Front Facing Camera Replacement, Front Facing Camera: шаг 12, изображение 1 из 1
    • Remove the upper display assembly bracket.
  13. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 13, изображение 1 из 1
    • Using the flat end of a spudger, disconnect the front-facing camera cable connector.
  14. Samsung Galaxy S4 Front Facing Camera Replacement: шаг 14, изображение 1 из 1
    • Remove the front-facing camera.
Заключение
66 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 854 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 198 руководств
10 Комментариев
Hi my front camera is bright white all of a sudden... is it broken or am I I'm some sort of mode it's only the front facing cam. .
James - Ответить
Any instructions for replacing the front speaker? I think I clogged it with glue when replacing the front glass.
Thanks!
Bill Carden - Ответить
Great set of instructions! Pictures are very accurate and helpful! When it only take 5-10 mins to do something you have never tried before, you know the instructions were excellent! Thanks
laura - Ответить
Excellent instructions. At step 12, the bracket is fragile and can easily ping off across the room so be careful. Thanks.
Ageingjedi - Ответить
My front camera is a bright white also, even on video recording but you can still hear sound.
Cin - Ответить
My screen cracked today right where my front facing camera is. I now cannot take pictures unless I use my rear camera. Will replacing the screen fix this or do I need to replace the camera too?
Elizabeth Klaas - Ответить
hi my camera ( front & back) on my samsung galaxy s4 will not work, the screen is black, everything else works great
Peggy Jones - Ответить
My phone got wet from the rain but not soaked I took phone apart and let it dry once it was dry I put it together. However my front camera doesn't work. It freezes what ever was displayed on the back screen. Is there anything to do to fix it ?
Aliyah j - Ответить
I am considering doing this... It looks simple enough with the help of your awesome instructions...thanks kindly wish me luck!!
shanny2829 - Ответить
My samsunng galaxy s4 the front facing camera is broken.
dyehenry - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 24
За всё время: 65,864
