Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace a microSD card in your Samsung Galaxy S4.
Выберете то, что вам нужно
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
28 участников успешно повторили данное руководство.
Один комментарий
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
