Введение
Use this guide to replace the motherboard in your Samsung Galaxy S4.
Выберете то, что вам нужно
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
I agree with the comment above
I also don't have a plastic tool and my finger nail won't pop the card out.
Grethe Montano. September 22
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
How much cost will be on replace a midframe
I purchased a 1.5x40mm Phillips screw driver and was able to remove all 9 40mm screws from the midframe as per the Step 6 Midframe instructions.
Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
Slide the opening tool along the seam, separating the plastic clips as you go.
I used same tool as in the photo and i broke the display. I think you should use a very thin plastic tool, such as a credit card but even more thin and flexible.
I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9.
Continue prying around the corner of the phone.
Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
Again, pry around the corner, to the power button side.
Slide the opening tool along the seam.
Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
On my phone, there was another clip holding the white midframe to the battery compartment, in the middle of the top edge of the battery compartment, near the battery contacts. If you don't release that before removing the midframe, it is easy to break.
I purchased a blue plastic opening tool(AKA: Spudger) and was able to remove the midframe from the display assembly as per the Step 7. I had to hold the cell phone firmly in my left hand while I gently forced the spudger between the chrome bezel and the midframe with my right hand and heard plastics clips separate and saw the midframe start to separate from the display assembly. Don’t be afraid to get that spudger in and just gently go down the side of the phone and you will hear the plastics clips detach and the midframe to separate more and more until you are able to separate them 100%. I started at the volume button side of the phone in Step 7 and ended at the power button side in Step 9. In Step 10 just make sure all the plastic clips are separated from the midframe and the display assembly so you can pull them apart 100% without breaking them.
Remove the midframe from the display assembly.
My Sprint S4 was slightly different then the one pictured above but I just completed this repair in under 10 minutes.. It would have been slightly quicker but fooling around with those little screws can be irritating if you have big hands.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Disconnect the headphone jack assembly cable connector.
Disconnect the display/digitizer cable connector.
Disconnect the antenna cable connector.
My model had an antenna connection next to the usb board connector in addition to the antenna connection near the display cable connector.
That's point a, on the daughter board (where the USB is located is point b. You must connect it from a to b
I could not get the screen connector to fit on with the motherboard assembly in place. I had to remove the motherboard assembly, attach the screen connector, and then carefully replace the motherboard assembly, with the screen connector still attached..
Same as Tom4G above. When trying to connect the screen connector, it would not give me that nice clear snap indicating a positive connection. The phone powered up with no screen. So, I disconnected the other connectors again, lifted the motherboard out and connected the screen connector by pinching it with finger and thumb from both sides of the motherboard, this time getting a nice snap when it engaged.
speedrzr -
Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
159 участников успешно повторили данное руководство.
30 Комментариев
I have a M919 with dead motherboard. Can i swap with an i9505motherboard insted? will all the components work on this new motherboard?
Hi I have a question. I have Galaxy S4 but The screen just broke and my sister give her galaxy s4 can i just change the motherboard to my phone or need to change the other parts too? Please help my i dont want to change all the parts if i dont need to!?
Mboard only.
i need S4 mother board too broher pls give me if you have extra i will pay
I wanted to know if I could swap my broken verizon gs4 motherboard with a us cellular gs4 motherboard
You should be able to, however it will only be comparable with US cellular
I wanted to know if I could swap my broken verizon gs4 motherboard with a us cellular gs4 motherboard??
I have a galaxy s4 and it won't power up could this be the motherboard
my screen shows the samsung logo and then it black outs what could be the problem
Could either be the battery or a software problem. If it's not the battery then downlad your stock rom and flash it with odin.
Myron -
Hi I have a Samsung Galaxy S4 that wont turn on or charge, I've been told its the mother board by a Samsung engineer whos checked the phone over. If the motherboard can be changed will I still keep all of me texts, contacts, pictures etc that are stored on this phone or will they be lost? I've not uploaded them to the cloud and worried Im going to loose everything. Please help Thanks!
Paula, if you did not store the information on SD card, that information resides on the motherboard'smemory chip. You may want to try KIES to be able to recognize your phone and download the information to your computer.
I have Samsung Galaxy s4 gt.i9500 I want mother board
You want motherboard?
Myron -
Thank you so much! This tutorial was incredibly helpful and was very well put together,extremely informative, and easy to read and follow.
Hi boss I want to change my phone ram
My phone 2gb but I want change into 4gb on motherboard it can possibility
My phone samsung j5 prime
I want increase my ram
Can u help me
my sim card are geting resisterd on network but it wont make a call and say not resisted on network and yet the phone is working well only sim prob but on an repair shop the shopkiper ask that motherbor may not working properly isbits posible
Sam, Thank you very much for this tutorial with pictures. I had bricked my Samsung S4 recently and could not revive it. I was successfully and economically able to replace the motherboard and revive the phone. I also appreciate comments about dual antenna - my phone had them - and cautions by other readers.
Prashant
1 want Samsung gt-i9505 mother board factory unlocked to all networks
my samsung s4 didn’t work. i don’t know why but the problem is if i switch on it will vibrate only but can’t open. how to work for this? please help me guys. thank you and godbless..
i wnat samsung wave 3 gt-s8600 motherboard.
I want samsung wave 3 gt-s8600 motherboard,
mine wont just respond even when powered i tried getting a new battery but its still blank help me guys.
