Введение
Use this guide to remove and replace the battery in a Samsung Galaxy S5 mini.
If your battery is swollen, take appropriate precautions.
  1. Insert a fingernail or a plastic opening tool into the slot located above the power button. Gently pull the panel off the back of the phone. The plastic snaps will make a popping sound as they separate.
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
  2. PC Laptop Batteries
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  3. Insert fingernail or plastic opening tool into the slot at the bottom of the battery. Gently pry the battery away from the phone. When replacing the battery, ensure the contacts are aligned and press lightly.  The battery will appear to fit in multiple directions, so do not force it in.
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
Заключение
6 участников успешно повторили данное руководство.
Ethan Juhnke
Участник с: 29.09.2014
153 Репутация
1 Guide authored
Команда
Cal Poly, Team 12-4, Forte Fall 2014 Member of Cal Poly, Team 12-4, Forte Fall 2014
CPSU-FORTE-F14S12G4
5 членов
Автор 35 руководств
Один комментарий
that was so so hard!
dennysb de - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 4
За 7 дней: 25
За 30 дней: 84
За всё время: 5,889
