Введение
Use this guide to remove and replace the battery in a Samsung Galaxy S5 mini.
If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Insert a fingernail or a plastic opening tool into the slot located above the power button.
Gently pull the panel off the back of the phone.
Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
Gently pry the battery away from the phone.
7 участников успешно повторили данное руководство.
2 Комментариев
that was so so hard!
But battery not charging properly
Hi, Yesterday I added a comment (although I can’t it on the site right now) I stated that the back on my S5 Mini was stuck on, not held by clips as you say in your S5 instructions. This was wrong. ''''
''''I wrongly thought my phone was an S5 Mini when in fact it’s an S6. I had forgotten that I had upgraded to the S6 some time ago and had not disposed of the S5 box etc. I will now rest my three remaining brain cells before attempting the repair of the S6.
Richard Kelsall - Ответить
