Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prereq to remove the motherboard from the interior midframe.
Выберете то, что вам нужно
Carefully wedge the tip of a spudger underneath the antenna cable connector.
Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
Remove the single 3.0 mm Phillips #000 screw securing the motherboard to the midframe.
Pull, but do not remove, the camera end of the motherboard up from the midframe to allow access to the connectors on the rear.
Use the flat end of a spudger to pry the daughterboard connector straight up off its socket on the motherboard.
Еще один человек закончил это руководство.
