Введение
This guide will show you how to replace the front-facing camera on this device. As with the back-facing camera, this replacement will require most of the phone to be taken apart beforehand.
Инструменты
Запчасти
Turn on the heat gun.
Hold the heat gun roughly 6 inches away from the screen of the phone and slowly run the heat around the edge of the screen.
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
5 участников успешно повторили данное руководство.
