Введение
This guide will show someone how to remove the screen from the phone. It does require several specialized tools, but the actual removal of the screen is relatively simple. However, because this is a waterproof device, removing the screen on this device WILL break the screen and make it unusable. Before beginning the removal process, be sure that you have a replacement screen.
Выберете то, что вам нужно
Turn on the heat gun.
Hold the heat gun roughly 6 inches away from the screen of the phone and slowly run the heat around the edge of the screen.
Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
3 участников успешно повторили данное руководство.
