ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
Π’ΠΈΠ΄Π΅ΠΎ ΠΎΠ±Π·ΠΎΡ€
  1. Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement. Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement. Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
    • Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
  2. Please be careful when remove the back cover! It's just a little weak.
    • Please be careful when remove the back cover! It's just a little weak.
  3. And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers. At last, push the camera lens glass by your finger or with a spudger and remove it finally. At last, push the camera lens glass by your finger or with a spudger and remove it finally.
    • And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers.
    • At last, push the camera lens glass by your finger or with a spudger and remove it finally.
  4. Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring. Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring. Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring.
    • Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring.
  5. Peel off the bottom film and we can stick the new camera lens assembly back. And one tips: you will need a piece of new back cover sticker because the old one maybe can't be used any more.
    • Peel off the bottom film and we can stick the new camera lens assembly back.
    • And one tips: you will need a piece of new back cover sticker because the old one maybe can't be used any more.
    • That's the guide to replace S6 camera glass and camera ring together.
  6. If your S6 camera lens was broken heavily, just remove it directly but very carefully. Don't hurt the camera or scratch the metal ring.
    • If your S6 camera lens was broken heavily, just remove it directly but very carefully. Don't hurt the camera or scratch the metal ring.
  7. Place the sticker on the camera ring at first. Place the sticker on the camera ring at first. Place the sticker on the camera ring at first.
    • Place the sticker on the camera ring at first.
  8. And then stick on the new camera glass and done the replacement. That's the guide for replace S6 camera glass only.
    • And then stick on the new camera glass and done the replacement.
    • That's the guide for replace S6 camera glass only.
Π—Π°ΠΊΠ»ΡŽΡ‡Π΅Π½ΠΈΠ΅
54 участников ΡƒΡΠΏΠ΅ΡˆΠ½ΠΎ ΠΏΠΎΠ²Ρ‚ΠΎΡ€ΠΈΠ»ΠΈ Π΄Π°Π½Π½ΠΎΠ΅ руководство.
Sophia
Участник с: 25.03.2014
43Β 516 РСпутация
Автор 62 руководств
ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠ΅Π²: 27
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Alex Sangue - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Yes, that is possible!
Robin -
I am wondering the same thing. I believe it would work. Don't see the need in pulling the back cover to replace a piece of exposed glass.
4freese - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
vicbliz - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
The guide for replacing a heavily broken camera lens is starting from step 6.
tkuilman1 - ΠžΡ‚Π²Π΅Ρ‚ΠΈΡ‚ΡŒ
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
ΠŸΡ€ΠΎΡΠΌΠΎΡ‚Ρ€ статистики:
Π—Π° послСдниС 24часов: 9
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 42
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 199
Π—Π° всё врСмя: 193,552
