Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
  1. Этот шаг не переведен. Помогите перевести
    Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone. Do not insert the tool into the microphone hole or you could cause damage. Look for the outline of the SIM tray. Press to eject the SIM card tray.
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
    • Do not insert the tool into the microphone hole or you could cause damage. Look for the outline of the SIM tray.
    • Press to eject the SIM card tray.
    • Remove the SIM card tray from the phone.
  2. Этот шаг не переведен. Помогите перевести
    We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  3. Этот шаг не переведен. Помогите перевести
    Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  4. Этот шаг не переведен. Помогите перевести
    Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  5. Этот шаг не переведен. Помогите перевести
    Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive. If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Shift the iOpener to heat the remaining section of the panel for another two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  6. Этот шаг не переведен. Помогите перевести
    Once the rear glass is hot to the touch, apply a suction cup near the bottom edge  of the glass. Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap. Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
    • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  7. Этот шаг не переведен. Помогите перевести
    Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass. Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
  8. Этот шаг не переведен. Помогите перевести
    Repeat the heating and cutting procedure for the remaining three sides of the phone. Leave an opening pick under each edge to prevent the adhesive from resealing. Leave an opening pick under each edge to prevent the adhesive from resealing.
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
  9. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  10. Этот шаг не переведен. Помогите перевести
    Use an opening pick to slice through any remaining adhesive. Remove the rear glass.
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
  11. Этот шаг не переведен. Помогите перевести
    To install new rear glass: Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • To install new rear glass:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
  12. Этот шаг не переведен. Помогите перевести
    Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
    • Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
  13. Этот шаг не переведен. Помогите перевести
    Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone. Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone. Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
    • Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
  14. Этот шаг не переведен. Помогите перевести
    Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard. Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
    • Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
  15. Этот шаг не переведен. Помогите перевести
    Disconnect the home button ribbon cable from the motherboard. Disconnect the home button ribbon cable from the motherboard.
    • Disconnect the home button ribbon cable from the motherboard.
  16. Этот шаг не переведен. Помогите перевести
    Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard. Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard. Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
    • Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
  17. Этот шаг не переведен. Помогите перевести
    Disconnect the display ribbon cable from the motherboard using the flat end of the spudger. Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
    • Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
  18. Этот шаг не переведен. Помогите перевести
    Disconnect the earpiece ribbon cable from the motherboard. Disconnect the earpiece ribbon cable from the motherboard.
    • Disconnect the earpiece ribbon cable from the motherboard.
  19. Этот шаг не переведен. Помогите перевести
    The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage. Grip the motherboard on both edges toward the top of the device.
    • The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage.
    • Grip the motherboard on both edges toward the top of the device.
    • Do not lift the motherboard all the way out in this step; the ribbon cable on the underside needs to be disconnected first.
    • Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
  20. Этот шаг не переведен. Помогите перевести
    Disconnect the daughterboard ribbon cable from the underside of the motherboard. Disconnect the daughterboard ribbon cable from the underside of the motherboard.
    • Disconnect the daughterboard ribbon cable from the underside of the motherboard.
  21. Этот шаг не переведен. Помогите перевести
    Using the flat end of a spudger, pry up the front facing camera's connector. Carefully remove the front facing camera from the motherboard. Carefully remove the front facing camera from the motherboard.
    • Using the flat end of a spudger, pry up the front facing camera's connector.
    • Carefully remove the front facing camera from the motherboard.
  22. Этот шаг не переведен. Помогите перевести
    Using a spudger, pry up the connector for the rear facing camera from the motherboard. Remove the rear facing camera from the motherboard. Remove the rear facing camera from the motherboard.
    • Using a spudger, pry up the connector for the rear facing camera from the motherboard.
    • Remove the rear facing camera from the motherboard.
  23. Этот шаг не переведен. Помогите перевести
    Remove the microphone from the motherboard. Remove the microphone from the motherboard.
    • Remove the microphone from the motherboard.
Финишная черта
23 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 18.10.2012
400 998 Репутация
Автор 547 руководств
Команда
iFixit Участник iFixit
Community
111 членов
Автор 10 650 руководств
Комментариев: 4
Where can i buy this Motherboard/Logicboard ?at least for under 80 € any chance ?!
Levin - Ответить
I cant get the wifi cables to re attach to the motherboard connectors ? Is there a special tool ?
Dennis - Ответить
Bonjour, je recherche une carte mère s6 Edge Samsung SM-G925 F 32GB d'occasion en bon état de de fonctionement.
Pour me contacter email: gilles_clavreul@hotmail.fr
MERCI
gilles_clavreul - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 52
За последние 30 дней: 237
За всё время: 15,902
