Введение
Prereq to remove the motherboard.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Запчасти
Детали не указаны.
  1. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard. Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
    • Use the pointed edge of a spudger to disconnect the Bluetooth and Wi-Fi antenna cable connectors from their sockets on the motherboard.
  2. Use the flat end of the spudger to disconnect the home button connector. Use the flat end of the spudger to disconnect the home button connector.
    • Use the flat end of the spudger to disconnect the home button connector.
  3. Use the flat end of a spudger to disconnect the display assembly cable from the motherboard. Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
    • Use the flat end of a spudger to disconnect the display assembly cable from the motherboard.
  4. Disconnect the earpiece speaker assembly cable  connector from the motherboard. Disconnect the earpiece speaker assembly cable  connector from the motherboard.
    • Disconnect the earpiece speaker assembly cable connector from the motherboard.
  5. Lift the camera-side end of the motherboard to separate it from the display frame. You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Lift the camera-side end of the motherboard to separate it from the display frame.
    • You may need to move some of the ribbon cables out of the way while you lift the motherboard. If the board is hard to lift, check that it is fully disconnected and not caught on any ribbon cables.
    • Do not fully remove the motherboard yet—it is still attached to the daughterboard via a ribbon cable on the underside of the motherboard.
  6. Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard. Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable connector from its socket on the underside of the motherboard.
Заключение
To reassemble your device, follow these instructions in reverse order. When reinstalling the rear glass, refer to the rear glass adhesive replacement guide.
3 участников успешно повторили данное руководство.
Evan Noronha
Участник с: 05.02.2015
206 517 Репутация
Автор 178 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 057 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 827
