Введение
Samsung has used the same screws in all mobile phone from the S3 - S5 models including the minis. The S6 series brought about new screws and if mixed up screws in too far and causes damage.
3.2mm S6 / S6 Edge & S7 series screws are 3.2mm.
Using 3.8mm screw around edges S6 / S7 Edge will cause damage to the LCD as per photo. Only ever use 3.2mm phillips head screws on S6 and S7 screen replacements.
28 участников успешно повторили данное руководство.
Один комментарий
Some of the screws in my S6 seem to be even shorter than 3.2 mm . Is that right? And in which holes do those fit? I think I mixed them up...
