Введение
This guide will show you how to replace the Samsung Galaxy S7 Active front camera.
Выберете то, что вам нужно
Melt the adhesive on the screen by applying a blow dryer directly on the screen.
Wedge the metal spudger in between the screen and the frame to begin separating them.
Use tweezers to take out the middle button and its connection to the motherboard.
Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
Use tweezers to disconnect the front mic and the two cables that have been marked in the photo.
Use your hands and a metal spudger to lift the motherboard out of the phone.
Use a metal spudger to remove this connection.
Use tweezers to remove the connection between the motherboard and the front camera.
