Видео обзор
技术规格,为何似曾相识。木有原因。
双曲面 5.5 英寸 Super AMOLED 触摸屏,2560 × 1440 分辨率(530 ppi)
高通骁龙820处理器,4GB 内存 ,Adreno 530 GPU
1200万像素后置摄像头 和双像素自动对焦, 4K 视频录制; 500万前置摄像头
32 or 64 GB 内置储存,可拓展microSD可(最高200 GB)
IP68 级防水能力
Android 6.0 Marshmallow
各位,好消息!电池不再和上一代的Edge一样放置在主板之下。
我们取出了高达3.85 V,13.86 Wh,3,600 mAh的超大电池
这比S7上的 3000 mAh电池还要大20%。这似乎是牺牲了厚度,来换取更长的电池寿命和频繁充电的次数。太好了!
在Grabthar的锤子之下,毫无保留。
接下来,是时候用数字来传达一些芯片的编号。在主板的正面,我们标记了:
SK 海力士 H9KNNNCTUMU-BRNMH 4 GB LPDDR4 SDRAM 和高通骁龙 820 MSM8996 封装在一起
三星 KLUBG4G1CE 32 GB MLC UFS2.0
安华高 AFEM-9040 多频多模模块
Murata FAJ15 前段模块
高通 WCD9335 音频编解码器
Maxim MAX77854 电源管理集成电路和MAX98506BEWV 音频放大器
Особая благодарность этим переводчикам:
60%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
74 Комментариев
When taking the phone apart, I assume that naturally you are throwing some if not all of the water resistant (or proof) capabilities behind, or is that not the case? Maybe you can re-waterproof it again, who knows.
Hello and good afternoon Joshua,
I have had to perform the same teardown on my Galaxy S7. After putting everything back together, I wanted to test the same theory. My phone was still very water resistant (I literally dropped it in a sink of water by mistake lol). But I've seriously had no problems with my S7 after. Hope the same success follows your projects. Have a great day!
There is some discussion as to whether the S7 phones support the extra speeds in UHS-II microSD cards - which would require an extra row of pins in the reader. The preliminary benchmarks of UHS-II cards show disappointing performance below the maximum speed of a UHS-I port, so it is doubtful that the reader is a full UHS-II reader, but it would be nice if the teardown could confirm the pin configuration of the microSD port so we can put the issue to rest...
