Введение
Samsung Galaxy s7 If your home button is not working? Solution! How to fix any Samsung Galaxy Home Button Galaxy g930F!
Выберете то, что вам нужно
Видеоинструкции
Почти готово!
Заключение
2 участников успешно повторили данное руководство.
5 Комментариев
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - Ответить
Thanks for you info.
www.movilone.es
MovilOne - Ответить
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - Ответить
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - Ответить
