Samsung Galaxy S7 Power/Volume Button Flex Replacement
Выберете то, что вам нужно
Видеоинструкции
Заключение
10 участников успешно повторили данное руководство.
Witrigs
Участник с: 11/24/15
69 454 Репутация
Автор 378 руководств
2 Комментариев
Is there something on the motherboard that could be damaged that would stop the volume buttons from working? Got a customer's phone where their volume buttons don't work post screen replacement. Just tried replacing the volume button flex but no luck. They applied a software update but haven't tried a factory reset yet.
FixNcell Phone Repair - Ответить
First off, Thank you for the video ! Very helpful and thorough.
2 comments to make:
1) be aware that the back cover is glass, so therefore is extremely fragile when prying open/removing. I cracked mine, so need to replace that now. So, some additional tips (maybe additional/constant heat to loosen the glue ??) or caution is necessary for anyone not aware.
2) IF your only replacing the Volume Buttons, for me, I only removed the screws , the Antenna, and NFC module. Then I could unplug the volume control and replace. Without removing anything else as shown. Of course if your doing the power button as well, then you would have to continue further.
Robert Gibbon - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 62
За всё время: 29,108
