Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Видео обзор
Этот шаг не переведен. Помогите перевести
Apply a heated iOpener to a long edge of the phone for about two minutes.
When the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
Lift on the suction cup and insert an opening pick under the rear glass.
Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
Slide the opening pick down along the side of the phone, separating the adhesive.
Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
If you're cleaning the midframe surface with isopropyl alcohol, be careful not to get any alcohol on the wireless charging coil. The coil coating will break down if it contacts alcohol.
Remove the eight 3.5 mm Phillips screws securing the NFC antenna and charging coil assembly.
Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame.
Remove the antenna assembly.
Use the flat end of a spudger to lift the charging coil assembly out of the phone.
Use the flat end of a spudger to disconnect the battery connector.
Use the flat end of a spudger to unplug the display and digitizer connector.
Prepare an iOpener and apply to a long edge of the phone for about 2 minutes.
Once the screen is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
Lift on the suction cup, and insert an opening pick under the display assembly.
Once the pick is firmly inserted underneath the display, reheat and reapply the iOpener to soften the display adhesive.
Slide the opening pick down the side of the phone, separating the adhesive.
Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
Leave an opening pick on each side as you continue to prevent the adhesive from resealing.
Pry up the side of the display opposite the display cable so that the cable acts like a hinge as the phone opens.
Carefully lift the display away from the mid frame, gently pulling the display connector through the hole in the mid frame.
Remove the display.
After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
185 участников успешно повторили данное руководство.
29 Комментариев
The screen replacement went smooth. I just wish it included the adhesive. I didn't see the note where the adhesive needed to be ordered in addition to the screen. Otherwise everything went well.
Thanks
Samsung s7 ekran değişimi orjinal parça satın aldığınız zaman bu kadar uğraşmanıza gerek yok.
Yapıştırıcı da sadece arka kapağı yapıştırmak için gerekli oluyor
For the price of the screen, I can replace it in a Samsung repair center...
I just need to replace the glass, not all of the AMOLED touch screen... :-( Sorry but this didn't help me.
How much cost u paid to service centre for original display for samsung s7
You can not replace just the glass without special equipment (hot plate, laminator etc.)
