Samsung Galaxy S9 Plus Battery Replacement
Выберете то, что вам нужно
Видео обзор
  1. Samsung Galaxy S9 Plus Battery Replacement, Rear Glass Removal: шаг 1, изображение 1 из 1
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy S9 Plus is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Plus Battery Replacement: шаг 2, изображение 1 из 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Plus Battery Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 3, изображение 2 из 2
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap and slide it to the bottom right corner.
  4. Samsung Galaxy S9 Plus Battery Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 4, изображение 2 из 2
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick at the bottom end of the phone. This opening pick stays there during the rear glass removal procedure to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Plus Battery Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 5, изображение 2 из 2
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
    • Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
    • Slide the opening pick from the bottom right corner half way up the frame and leave it there.
  6. Samsung Galaxy S9 Plus Battery Replacement: шаг 6, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 6, изображение 2 из 2
    • Insert a fourth opening pick at the right side of the frame and slide it to the top right corner.
    • Slide a fifth opening pick along the left side of the phone to the top left corner.
    • Use the opening pick to cut the remaining adhesive under the upper part of the rear glass.
    • Don't open the phone all the way yet. The flex cable for the fingerprint reader is still connected to the motherboard.
  7. Samsung Galaxy S9 Plus Battery Replacement: шаг 7, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 7, изображение 2 из 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  8. Samsung Galaxy S9 Plus Battery Replacement: шаг 8, изображение 1 из 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  9. Samsung Galaxy S9 Plus Battery Replacement, NFC Antenna and Charging Coil: шаг 9, изображение 1 из 1
    • Remove the nine 4 mm Phillips #00 screws.
  10. Samsung Galaxy S9 Plus Battery Replacement: шаг 10, изображение 1 из 3 Samsung Galaxy S9 Plus Battery Replacement: шаг 10, изображение 2 из 3 Samsung Galaxy S9 Plus Battery Replacement: шаг 10, изображение 3 из 3
    • Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
    • Flip the opening pick sideways to lift the cover out of its plastic clips.
    • Work your way around the plastic cover, prying up to release the remaining clips.
  11. Samsung Galaxy S9 Plus Battery Replacement: шаг 11, изображение 1 из 1
    • Remove the plastic cover containing the NFC antenna and the charging coil.
  12. Samsung Galaxy S9 Plus Battery Replacement, Battery Disconnect: шаг 12, изображение 1 из 1
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  13. Samsung Galaxy S9 Plus Battery Replacement, Battery: шаг 13, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement, Battery: шаг 13, изображение 2 из 2
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid this area. There's a gap in the mid-frame right below the battery, and you can accidentally damage the display through it.
  14. Samsung Galaxy S9 Plus Battery Replacement: шаг 14, изображение 1 из 2 Samsung Galaxy S9 Plus Battery Replacement: шаг 14, изображение 2 из 2
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery where the flex cable is located and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  15. Samsung Galaxy S9 Plus Battery Replacement: шаг 15, изображение 1 из 1
    • Insert the spudger at the top right corner of the battery and pry it up.
  16. Samsung Galaxy S9 Plus Battery Replacement: шаг 16, изображение 1 из 1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery and adhesive, follow this guide.
Заключение
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, calibrate your newly installed battery after completing this guide.
43 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
165 085 Репутация
Автор 661 руководств
Команда
iFixit Участник iFixit
Community
138 членов
Автор 16 959 руководств
4 Комментариев
One of the best “do it yourself” instructions I’ve ever come accross! Very thorough!!
AK Sand - Ответить
Just be careful to remember to try phone parts (such as, battery recharging OBV, Fingerprint sensor…) before closing with the new cover.
Also remember to attach the Wireless card before doing the battery test otherwise the phone will say that can’t charge because the phone is too cold.
That’s because on the wireless charger module there is the heat sensor.
Flavio - Ответить
Missed one of the most important parts: Where and how do you install the adhesive pieces? There are a lot of them and the linked article doesn't even come close to explaining it for this phone.
Jason Landon - Ответить
Good instruction, I was successful replacing the battery however I accidentally damaged the fingerprint scanner cable because the image showed above is mirrored and I sliced too far in on the wrong side.
Also, a brief note on which adhesives can/should be removed before reassembling would be very helpful.
Nick Tipton - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 66
За последние 7 дней: 453
За последние 30 дней: 2,204
За всё время: 103,708
