Введение
If the touch screen / digitizer / glass or the LCD display is broken, this manual will show you, how to disassemble the phone and replace the Display Assembly without frame.
[text|align=center]
_______________________________________ Video tutorial _______________________________________
Выберете то, что вам нужно
Видео обзор
LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
Switch off the phone, remove the battery and any SIM and memory card.
Disconnect:
Menu buttons flex cable
Micro SD Card reader flex cable
Lift up slightly the mother board from the right edge.
Now disconnect the LCD Display flex cable which is located on the underside of the board.
Front camera
Main / Rear camera
Earpiece
Loudspeaker
Vibro motor
Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
Use the front camera hole to separate the glass at the corner.
Continue with separation with plastic tools, from up to down.
18 участников успешно повторили данное руководство.
2 Комментариев
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
