Введение
Using these steps, you can replace the front camera on your Galaxy SIII Mini VE.
Выберете то, что вам нужно
Flip your phone so you are facing the back.
Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
Use your finger or an opening tool to pry the battery out of the phone.
Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
Next, use the spudger and tweezers to remove the speaker at the top of the phone.
Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
Detach this connection using the spudger.
Locate the front camera connection.
Using the tweezers, lift the holding tab at the base of the ribbon wire.
Again, using the tweezers, gently pull the front camera out and away from the phone.
2 участников успешно повторили данное руководство.
