Введение
For the Cricket Samsung Galaxy Sol, this guide will teach you how to replace the Front Camera. Some problems that might cause this to become blurry could be water damage or dust blocking the camera.
Выберете то, что вам нужно
Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
Remove all ten 0.4 mm screws with a Phillips #00 screw bit. After this, you will be able to lift up and remove the grey plastic piece.
2 участников успешно повторили данное руководство.
