Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The mother board is the heart and soul of this device. Everything from the operation system to the camera and audio port runs through the motherboard. If either component is faulty then the whole mother board needs to be replaced. This guide will help show you how to replace the motherboard right in your own home.
Запчасти
Детали не указаны.
  1. Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Once rear cover is off use small pastic spudger to lift battery out of the phone Once rear cover is off use small pastic spudger to lift battery out of the phone
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. After following how to remove the battery, unscrew the five 1.2mm Phillips Screws  on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  5. Once screws are removed turn the phone over and use the plastic opening tool and  unclip the connector holding the screen to the motherboard.
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  6. Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  7. Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps. Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
Заключение
3 участников успешно повторили данное руководство.
Kevin Teque
Участник с: 10.03.2016
288 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 7-2, Catania Spring 2016 Участник UMass Dartmouth, Team 7-2, Catania Spring 2016
UMASSD-CATANIA-S16S7G2
3 членов
Автор 5 руководств
Комментариев: 2
more information please....
me good - Ответить
What information are you looking for?
Kelsea Weber -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 21
За всё время: 2,663
