Samsung Galaxy Star Pro Speaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Star Pro Speaker Replacement, Battery Replacement: шаг 1, изображение 1 из 1
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Samsung Galaxy Star Pro Speaker Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Star Pro Speaker Replacement: шаг 2, изображение 2 из 2
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Samsung Galaxy Star Pro Speaker Replacement, Screen: шаг 3, изображение 1 из 1
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
  4. Samsung Galaxy Star Pro Speaker Replacement: шаг 4, изображение 1 из 1
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
  5. Samsung Galaxy Star Pro Speaker Replacement: шаг 5, изображение 1 из 1
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
  6. Samsung Galaxy Star Pro Speaker Replacement, Motherboard: шаг 6, изображение 1 из 2 Samsung Galaxy Star Pro Speaker Replacement, Motherboard: шаг 6, изображение 2 из 2
    • Unscrew the 1.2mm Phillip screw that connects the motherboard to the rest of the phone. Then by using your thumbs pop the inners of the phone out. Also use same J00 Phillips head bit from prior steps.
  7. Samsung Galaxy Star Pro Speaker Replacement, Speaker: шаг 7, изображение 1 из 2 Samsung Galaxy Star Pro Speaker Replacement, Speaker: шаг 7, изображение 2 из 2
    • Use plastic tools to grab hold of one side of the speaker on the motherboard, and then gently lift. There is nothing holding the speakers, so it should come right off.
Заключение
4 участников успешно повторили данное руководство.
Kevin Teque
Участник с: 03/10/16
294 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 7-2, Catania Spring 2016 Участник UMass Dartmouth, Team 7-2, Catania Spring 2016
UMASSD-CATANIA-S16S7G2
3 членов
Автор 5 руководств
2 Комментариев
how cost spaeaker component
me good - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 1,225
