Введение
There are a few important things to recognize when replacing the charge port. The connection between ribbon cable and motherboard is initially tricky, but when you've loosened the connection, the ribbon cable will slide right out. There is some adhesive between the ribbon cable and the device near the charge port. It's okay to pull this loose because your new charge port will have more adhesive.
Выберете то, что вам нужно
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
Once the bottom edge has been loosened, work towards a bottom corner from the other edge and continue to wedge gently until you can “pop” the corner out.
Continue this process on the other bottom corner until it can be popped out as well.
Place your hand between the device and the back panel. Then continue the wedging motion along the top edge of the device until the back panel comes loose.
The connection between the battery and motherboard is a group of four wires in black housing that can be found near the top middle of the device. Using a plastic spudger or a flat, slim tool, lift the black connector housing upwards to disconnect it.
Slide a plastic spudger tool under the strip of black plastic on the back of the ribbon connector.
Gently lift with the spudger to flip the connector up. This will release the ribbon from its connection.
Slide the ribbon out of the connector.
Slide the plastic spudger under the charge port to lift it from it's housing.
Pull up on the charge port to remove it and its ribbon cable.
7 участников успешно повторили данное руководство.
