Введение
In this guide you will remove the entire SIM card reader assembly. This is not a complicated process, just make sure you don't misplace the 4 screws.
Выберете то, что вам нужно
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
Once the bottom edge has been loosened, work towards a bottom corner from the other edge and continue to wedge gently until you can “pop” the corner out.
Continue this process on the other bottom corner until it can be popped out as well.
Place your hand between the device and the back panel. Then continue the wedging motion along the top edge of the device until the back panel comes loose.
The connection between the battery and motherboard is a group of four wires in black housing that can be found near the top middle of the device. Using a plastic spudger or a flat, slim tool, lift the black connector housing upwards to disconnect it.
Use a Phillips #00 screwdriver to remove all 4 black 2.5mm screws securing the silver SIM card reader to the motherboard.
Using a plastic spudger, gently pop the SIM card reader connection off the motherboard.
Lift the SIM card reader off the motherboard, and replace it with a new SIM card reader.
Еще один человек закончил это руководство.
