Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
In this guide, you will learn how to replace the battery on your Samsung Galaxy Tab 10.1. Having a bad or broken battery can be frustrating. There are a couple prerequisites we need to get out of the way first!
  1. Place the bottom of the tablet towards you. Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
    • Place the bottom of the tablet towards you.
    • Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly. Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device. Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  5. Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables. Carefully pull the three ribbon cables from their sockets on the motherboard. Carefully pull the three ribbon cables from their sockets on the motherboard.
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  6. Remove the ten 3 mm Phillips #00 screws surrounding the battery. Remove the ten 3 mm Phillips #00 screws surrounding the battery.
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  7. Lift the edge of the battery up with your finger or a spudger. Detach the battery by holding the motherboard down while gently lifting the battery up. Detach the battery by holding the motherboard down while gently lifting the battery up.
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
Заключение
57 участников успешно повторили данное руководство.
Jess McCafferty
Участник с: 30.09.2013
1 644 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 13-5, Forte Fall 2013 Участник Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 членов
Автор 17 руководств
Комментариев: 18
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
zen - Ответить
What if your stupid aunt is trying to open it and you can open it but she said that you broke it? What can I do about it. Ppl. HM
Isabella - Ответить
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
Tomjonkins - Ответить
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
Scott Waschlerner - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 25
За последние 7 дней: 184
За последние 30 дней: 895
За всё время: 344,070
