Введение
In this guide, you will learn how to replace the motherboard on your Samsung Galaxy Tab 10.1. A faulty motherboard can lead to a multitude of performance issues, especially if your device doesn't turn on at all. There are a couple prerequisites we need to get out of the way first!
Выберете то, что вам нужно
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
Lift the edge of the battery up with your finger or a spudger.
Detach the battery by holding the motherboard down while gently lifting the battery up.
Hold down the motherboard with your finger and use a spudger to gently pry up the connection for the volume keys and power key.
Using the flat end of a spudger, disconnect the black flash cable connector from the motherboard.
Disconnect the white rear-facing camera connector.
Use the flat end of a spudger to disconnect the orange front-facing camera connector.
Disconnect the blue Micro SD card/headphone jack connector from its socket on the motherboard.
Using the flat end of a spudger, disconnect the orange speaker connectors for the left and right speakers.
Disconnect the gold antenna cable connector from its socket on the motherboard.
Lifting from the bottom edge, gently remove the motherboard.
18 участников успешно повторили данное руководство.
5 Комментариев
Comment passe t'on de l'étape 6 à 7 ? (plastique gris qui fait le tour)
My 10.1 tablet switches on but the only thing showing on the screen is the “Samsung Galaxy 10.1” logo.
If the on/off button is held down for 20 seconds or so the screen goes blank for a few seconds then the logo reappears but nothing else happens. This logo only disappears when the battery is fully discharged.
After re-charging the battery the whole process is repeated
Any suggestions as to the problem
Jim
I'm having the same issue
have anyone found a solution?
What if I don't have screws on the outside of tablet?
