Введение
In this guide, you will learn how to replace the LED flash light on your Samsung Galaxy Tab 10.1. Having a malfunctioning flash can lead to poor lighting in the pictures taken on the tablet. There are a couple prerequisites we need to get out of the way first!
Выберете то, что вам нужно
Place the bottom of the tablet towards you.
Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
Carefully pull the three ribbon cables from their sockets on the motherboard.
Lift the edge of the battery up with your finger or a spudger.
Detach the battery by holding the motherboard down while gently lifting the battery up.
Use your spudger to gently pry up the black connection of the LED flash from the motherboard.
Еще один человек закончил это руководство.
