Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
In this guide, you will learn how to remove the back panel for either replacement or to get to other components in your Samsung Galaxy Tab 10.1.
  1. Place the bottom of the tablet towards you. Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
    • Place the bottom of the tablet towards you.
    • Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly. Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device. Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  4. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Заключение
12 участников успешно повторили данное руководство.
Davie Sy
Участник с: 30.09.2013
1 369 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 13-5, Forte Fall 2013 Участник Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 членов
Автор 17 руководств
Комментариев: 3
Very interesting, but my note 10.1 does not have these two screws adjacent to the charge point as you describe. So mine is a bit different. There are no screws anywhere on the tablet. So how do I take the back off mine ??
James Tobin - Ответить
It currently won’t start and I have read about a fix that requires the back to be removed.
What - How - Ware ? Yes I looked online for the parts, no I was not successful in finding the parts online. Can you tell me ware you found the parts for this project?
Brian Elling - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 20
За последние 30 дней: 82
За всё время: 36,342
