Samsung Galaxy Tab 2 10.1 Speaker Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Back Cover: шаг 1, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Back Cover: шаг 1, изображение 2 из 2
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
  2. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 2, изображение 2 из 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Battery Disconnect: шаг 3, изображение 1 из 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 4, изображение 1 из 3 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 4, изображение 2 из 3 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 4, изображение 3 из 3
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Front Camera: шаг 5, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Front Camera: шаг 5, изображение 2 из 2
    • Gently lift the camera from its socket with the flat end of the heavy-duty spudger.
  6. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 6, изображение 1 из 1
    • Gently lift the gold cable connector with the flat end of the heavy-duty spudger to disconnect it from the device.
  7. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Battery: шаг 7, изображение 1 из 3 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Battery: шаг 7, изображение 2 из 3 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Battery: шаг 7, изображение 3 из 3
    • Using your fingers, remove the green tape holding the three ribbon cables down.
    • Using the flat end of the heavy-duty spudger, carefully lift the black tab that holds the leftmost, black ribbon cable in place. Repeat this step for the gold ribbon cable and the black ribbon cable.
    • Using your fingers, gently slide each of the three cables straight out of the connectors.
  8. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 8, изображение 1 из 1
    • Using a Phillips #000 screwdriver, remove the ten 3mm screws that hold the battery down.
  9. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 9, изображение 2 из 2
    • Lift the battery with your hands and remove it from the device.
  10. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Motherboard: шаг 10, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Motherboard: шаг 10, изображение 2 из 2
    • Using the flat end of the heavy-duty spudger, lift up the black ribbon lock directly left of the headphone jack from the black side.
    • After lifting up the lock, insert the heavy-duty spudger underneath the gold ribbon and slide to disconnect the gold ribbon.
  11. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 11, изображение 1 из 1
    • The rear camera may pop out.
    • Using the flat end of the heavy-duty spudger, gently lift up the ribbon lock directly above the one in the previous step from the brown side.
    • After lifting up the lock, remove the gold ribbon with the heavy-duty spudger as you did in the previous step.
  12. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 12, изображение 1 из 1
    • Use the flat end of the heavy-duty spudger to pop off and disconnect all the marked connectors attached to the motherboard.
  13. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 13, изображение 2 из 2
    • After disconnecting all of the connectors, push up on the motherboard with your thumbs to dislodge it from the tabs fastening the bottom of the motherboard. Then lift up the motherboard to carefully remove it from the device.
    • You may need to repeat this step a few times. The motherboard can be difficult to remove.
  14. Samsung Galaxy Tab 2 10.1 Speaker Replacement, Speaker: шаг 14, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement, Speaker: шаг 14, изображение 2 из 2
    • Using the plastic opening tool, gently pry the left speaker out of the slot and remove it
  15. Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 15, изображение 1 из 2 Samsung Galaxy Tab 2 10.1 Speaker Replacement: шаг 15, изображение 2 из 2
    • Using the plastic opening tool, gently pry the right speaker out of the slot and remove it
Заключение
5 участников успешно повторили данное руководство.
Matthew Weeman
Участник с: 02/02/15
927 Репутация
1 руководство автора
Команда
Cal Poly, Team 6-26, Amido Winter 2015 Участник Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 членов
Автор 14 руководств
Один комментарий
I have a little grey rubber unit which has fallen out of somewhere. Can you say where this goes please. Someone said it was to do with the speaker. Its only about a centimetre wider.
Bernard Kane - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 2,614
