Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Carefully start at the bottom of the tab prying the rear casing. Be careful prying, if you apply too much pressure you can crush the back. Be careful prying, if you apply too much pressure you can crush the back.
    • Carefully start at the bottom of the tab prying the rear casing.
    • Be careful prying, if you apply too much pressure you can crush the back.
  2. Lift the back plate away from the tab. Lift the back plate away from the tab.
    • Lift the back plate away from the tab.
  3. disconnect the battery by prying from underneath where the wires attach. be careful prying. if you pry the connector you may rip it from the board. be careful prying. if you pry the connector you may rip it from the board.
    • disconnect the battery by prying from underneath where the wires attach.
    • be careful prying. if you pry the connector you may rip it from the board.
    What's after step 3?
    Stephen Knight - Ответить
    The guide is incomplete
    iPhone Rebel Repair - Ответить
    its now finished
    Wesley Burson -
  4. Remove the 6 screws holding in the battery] Then the battery should lift out
    • Remove the 6 screws holding in the battery]
    • Then the battery should lift out
  5. Next we will be disconnecting the cables shown in red
    • Next we will be disconnecting the cables shown in red
  6. the speaker connectors will be first. Use a plastic opening tool to pop the connector off
    • the speaker connectors will be first.
    • Use a plastic opening tool to pop the connector off
    • repeat this for the other connectors show on previous step
  7. remove the screws holding the speakers in. remove the screws holding the speakers in.
    • remove the screws holding the speakers in.
  8. lift both speakers out. lift both speakers out.
    • lift both speakers out.
  9. remove the motherboard screws as shown
    • remove the motherboard screws as shown
    A circle is wrong, meaning the one in the high-left showed in photo. If you don't have some experience, you can get confused, otherwise it wont matter.
    Nico Soranno - Ответить
  10. lift the motherboard out of the device lift the motherboard out of the device lift the motherboard out of the device
    • lift the motherboard out of the device
  11. flip it over and heat the glass using a heat gun, and insert your plastic opening tool. slowly work your way around the device reheating as needed. make sure the tool does not go too far into the device as it can break the lcd.
    • flip it over and heat the glass using a heat gun, and insert your plastic opening tool.
    • slowly work your way around the device reheating as needed.
    • make sure the tool does not go too far into the device as it can break the lcd.
    • When heating, don't use too much heat as you can burn the lcd.
  12. after filling it with a world share of plastic tools, lift the screen off. after filling it with a world share of plastic tools, lift the screen off.
    • after filling it with a world share of plastic tools, lift the screen off.
  13. feed the connector out of the frame. feed the connector out of the frame.
    • feed the connector out of the frame.
  14. remove the old adhesive. and clean the glass off the lcd
    • remove the old adhesive.
    • and clean the glass off the lcd
  15. reapply adhesive and feed the cable in the frame.
    • reapply adhesive and feed the cable in the frame.
    • Then do the whole guide in reverse minus the prying.
Заключение
27 участников успешно повторили данное руководство.
Wesley Burson
Участник с: 14.02.2014
2 257 Репутация
1 руководство автора
Команда
iRefresh Phones Участник iRefresh Phones
Business
1 член
Автор 1 руководств
Комментариев: 5
Hello! :)
Today I have replaced my screen following your guide and a YouTube video. They were both helpful :)
Just a warning, when you are taking off the old screen, trying to separate it from the glue, be careful not to insert the plastic tools too deep into the space between screen and glass, because you may damage the first one.
Good luck everyone! :D
Fil - Ответить
Can't see why it's necessary to remove the battery or motherboard. Why can't you heat the digitizer off, since there's access to the cable?
If the correct amount of heat is applied, why is this all necessary?
DNATECH LONDON - Ответить
The reason I recommend removing it is to help prevent the battery and motherboard from being accidentally heated. I know that if you do it just right there will be no heat applied to them but I'd rather be safe than sorry!
Wesley Burson -
I done this but new screen is not bonding well what are your recommendations
Elizabeth Mochrie - Ответить
I replaced the digitizer and battery on my son's tablet. Now the network card is hardly able to pick up a signal. I have read that some people replace the antenna, but I can't see how that would help as it is such a simple design.
David Johnson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 23,806
